Changing a life cycle state's name
- December 6, 2013
- 3 replies
- 1297 views
I inherited a life-cycle sequence that contains 'Under Review'. I'm using this currently as part of a Change Notice workflow. I've also set some policies to restrict/grant access to this life cycle state based on the users' role or group.
I'd like to rename this to something different. I notice in the Edit Life Cycle interface that each life cycle state has a pull down menu for State. I'd like to change this from 'Under Review' to 'Pending Approval' as a more accurate name for the actions taking place on these files while they're at this state. (See attached for example.)
Before making this I'd like to know if this is the road to ruin.
Will this upend all the policies I have dealing with 'Under Review'? I would hope these are tied together sufficiently to allow this sort of change. Policy Admin isn't that hard, but I'd like to know about it rather than have any unpleasant surprises.
Will this screw up our Change Notice's 'Lock Changeables', 'Unlock Changeables' and 'Release Changeables'? I would hope not because all the transtions would remain the same as they were previously.
