Changing a Projects Template
  • June 19, 2012
  • 691 views
I created a new Project in PDMLink 9.1 but used the wrong Template. I need to either change the Template or Delete the Project and recreate it but I can't figure out how to do either. Any suggestions?
John
It can be a real pain to delete.
You will need to rename the project (if you wish to reuse same name)
You will also need to remove everyone from the team of the project.
The second step hides incorrectly created project from other system users.
Sent from my Verizon Wireless BlackBerry
