Chose between Product and Library
  • January 26, 2024
  • 10 replies
  • 3114 views
When setting up Windchill for an organization or client, what factors do you typically weigh when choosing between containers (Product and Library)? While I've reviewed the definitions and PTC documentation, I am keen to learn the practical considerations that businesses should factor in regarding their products and end items. It would be great to have some real-life case studies illustrating these considerations.
https://www.ptc.com/en/support/article/CS22028
https://community.ptc.com/t5/Windchill/Product-and-Libraries/m-p/56936#M6852
https://support.ptc.com/help/wnc/r12.0.2.0/en/#page/Windchill_Help_Center%2FContextsAbout.html%23
Best answer by HelesicPetr
Hi @Srikanth1
A library usually is used for standard components used in all products. Usually you buy that standard components based on some ISO catalog etc.
Also drawing format and drawing templates are stored in the library
You can imagine that you store general documentation for standard Creo/Windchill usage as metrology guides
The library allows to restrict the access that standard users work in product can not change the library objescs
Product context is used for non standard product objects / models / documentation/ change management and  so on.
You can imagine any purpose to use library or product context.
For example a MPMLink library can be used for resource data as tools, work-centers etc that are not directly connected to a specific product..
PetrH
From a technical standpoint, I think the only difference is the Enditem table view available on the detail page within a product and not within a library.
From a process standpoint, you usually put in a library the elements that are reused across products to define them.
For example, it can be bought components, internal standard components, and common documents.
You may have specific business rules to manage these objects and you may set these rules at container level. For example, for library components, you may have a specific process to validate them.
From a user experience point of view, it helps the navigation among the containers, you can quickly access them rather than searching within a big product container list.
jbailey
18-Opal
January 26, 2024
I always draw the line at Change/Configuration Management. If you need change management, you should be doing it in a product. You cant do version control in a project... So no "real" release, Change Requests or Change notices either.
HelesicPetr
Hi @jbailey
the question is about Library no Project.
PetrH
jbailey
18-Opal
January 29, 2024
I know.  It was a subtle hint that data specific to things being made or developed should be in a Project or Product 🙂
HelesicPetr
Hi @Srikanth1
PetrH
Srikanth113-AquamarineAuthor
Thank you everyone for taking time to respond.
Upon highlighting the PTC definitions, recommendations, technical differences (No end items table, process plans,.. on library), we have recommended housing all engineering data within Product containers, while reserving libraries for generic reference documents unrelated to specific parts or assemblies.
You may want to reconsider that as the final answer. Using a Library for standard parts has some advantages.
We do our standard parts (nuts, washers, screws, bolts, etc.) in family tables and put them in the Library.Windchill can be set so Library items loaded into an assembly cannot be checked-out and modified by any user who is not a Librarian. This way your standard library parts are protected.
There are also reasons to store things like your drawing formats in a Windchill Library to prevent them from being changed by all of your users. The templates for start parts and drawings may also be stored in the Library, but we use a network shared disk for those files.
