Apr 21, 2025 8:15 AM UTC
Corp LDAP integration with Windchill
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.4
Our intension is to integrate Corp Active Directory with Windchill. So I followed Article to https://www.ptc.com/en/support/article/CS29454#4 to configure access to an additional LDAP Directory in Windchill. After doing all the steps given in the Article I'm unable to login to the server, I tried to login to wcadmin but still not able to login. Error message shows in log "Nested exception is: wt.org.OrganizationServicesIEException: javax.naming.CommunicationException: corpldap.mydomain.com:389"
    JimwangAnswer
    Apr 24, 2025 8:56 AM UTC
    To configure Windchill with Active Directory, you can refer to article https://www.ptc.com/en/support/article/CS29445.
    Per the message "javax.naming.CommunicationException: corpldap.mydomain.com:389", make sure your Windchill machine can connect to your AD server "corpldap.mydomain.com" via the port 389, otherwise, you may try other port like 3268 or check your AD admin.
    avillanueva
    23-Emerald II
    Apr 22, 2025 11:10 AM UTC
    Are you integrating just the webserver or did you also change your ie settings to connect to the same LDAP?
    Apr 22, 2025 12:11 PM UTC
    According to PTC, this is a port issue.  Most likely, the port is blocked by firewall.
    https://www.ptc.com/en/support/article/CS389562
    With Active Directory, use ports 3268 (LDAP) or 3269 (LDAPS).  The generic 389 and 636 ports don't provide access to the global catalog, which is commonly needed for Windchill LDAP integrations.
    FYI: It is a recommended practice to validate the corporate LDAP connection information provided by IT in an LDAP client like Apache Directory Studio before integrating.  It is best to know the server can connect to the LDAP server with the provided information before getting into a Windchill configuration debugging session.
    Jimwang16-PearlAnswer
