Create a folder automatically Windchill 10.1
  • May 13, 2013
  • 3 replies
  • 1500 views
There is a way to automatically create a folder in a product if this isn't exist?, by customization or configuration.
Thanks for the info that can provide me
avillanueva
23-Emerald I
May 14, 2013
Are you talking about a load file? That can be done. Customization sure, that should be easy. There is an API for that. What is the trigger for creating a folder?
The below code snippet helps your requirement...little modification is
required.
public static void creatDirectory(String array[], WTContainerRef
containerRef){
String path = ((WTContainer)
containerRef.getObject()).getDefaultCabinet().getFolderPath();
if(array != null){
int len = array.length;
Folder folder = null;
for(int i = 0; i < len; i++){
try {
folder = FolderHelper.service.getFolder(path, containerRef);
path = path + '/' + array[i];
QueryResult result = FolderHelper.service.findSubFolders(folder);
if(!checkFolder(result,array[i])){
FolderHelper.service.createSubFolder(path, containerRef);
} catch (WTException e) {
e.printStackTrace();
public static boolean checkFolder(QueryResult result, String str){
if(result == null){
return false;
while(result.hasMoreElements()){
Object object = result.nextElement();
if(object instanceof SubFolder){
SubFolder subfolder = (SubFolder)object;
if(subfolder.getName().equals(str)){
return true;
else{
return false;
return false;
Antonio:
The trigger is a process for upload a bunch of documents, already a customization, but if this process does not find the folder throws the document in the root folder, i'm looking for a way to improve it.
Gangadharan:
thanks for the answer, i will try your script
