Create Reference Document Subtype
  • June 10, 2014
  • 3 replies
  • 964 views
Hi all,
It appears that on our system someone has deleted the OOTB "Reference Document" Subtype. We have never used it in the past and were looking to test using it for some documents. I had assumed that it had been disabled and I would just be able to go in and enable it but it is missing. Does anyone know the steps it would take to recreate the OOTB "Reference Document" Subtype? Any help would be greatly appreciated.
Brian
bwilson-21-VisitorAuthor
Prajeesh,
Thanks for the info. I am running 10.1 M040 but the type is missing from my Dev server as well. I will have to see what I can do.
Brian
[cid:image001.gif@01CB6625.A4BF3A90]
Brian Wilson
SENIOR APPLICATION ENGINEER
8-Gravel
June 11, 2014
Double check the Policy Administrator if you haven't already. It is possible that rather than delete the type, there has been a DENY ALL ALLrule(s) applied to the type. This will impact Admin users as well as general users. Unlikely, but I have seen this be the case previously (although I'm not certain it impacts the 10.x Type Admin UI's.).
