Critical vulnerability CVSS10.0
I am using Windchill PDMLink Release 10.0 and Datecode with CPS M010
Critical vulnerability (CVSS10.0) in its Windchill and FlexPLM products. Want to add the immediate remediation steps but don't understand instructions.
Currently have "D:\ptc\Windchill_12.1\HTTPServer\conf\conf.d\30-app-Windchill-Auth.conf" file. Do I simply create the new 90-app-Windchill-auth.conf and ONLY put the entry that was sent in the remediation or do I copy the 30-app file renaming to 90-app and have all of my configuration settings plus remediation???
Some of the replies to this topic were published during the recent read-only period. We have manually republished the missing posts to preserve the integrity of the topic. Learn more.
April 2, 2026
The Community team
olivierlp
olivierlpAnswer
Community Manager
April 2, 2026
Initially posted by ​@sashelke on March 30, 2026
Hi ​@CC_3911250,
Since you are currently on Windchill PDMLink Release 10.0 with CPS M010, we have documented a remediation for this version in the following article:
@bmüller , For Windchill 11.0 and above, please follow the steps outlined in the referenced articles below:
For this update, you can create a new file in the 90–99 range.
From my understanding, the order does not matter as long as both files are placed at the end of the sequence.
I hope this provides the clarity you needed.
Best regards,
Samarth Shelke
Olivier
Hello @CC_3911250 ,
You need to create the 90-app-Windchill-auth.conf and ONLY put the entry that was sent in the remediation.
as per https://www.ptc.com/en/support/article/CS466318
Atharva
olivierlp
Community Manager
April 2, 2026
Initially posted by ​@bmüller on March 30,2026
Hi  ​@AtharvaD
with the second remediation, is there any reason to create 2 files with only those configs? or will one 90-... file with both work too? in "normal Apache" this should make no difference.
Bernhard
Olivier
Apache HTTP Server Configuration – Workaround Steps
  1. Create a new Apache configuration file:
    <APACHE_HOME>/conf/conf.d/90-app-Windchill-Auth.conf
  2. Add the following directive to the file:
    <LocationMatch "^.*servlet/(WindchillGW|WindchillAuthGW)/com\.ptc\.wvs\.server\.publish\.Publish(?:;[^/]*)?/.*$">
     Require all denied
    </LocationMatch>
  3. Save the configuration file.
    NOTE: If other Apache configuration files exist with sequence numbers higher than 90, ensure this new file is the last in the sequence.
  4. Restart Apache HTTP Server for changes to take effect:
    • Linux:
      apachectl stop
      apachectl start
    • Windows (Service):
      • Open Services
      • Stop Apache HTTP Server
      • Start Apache HTTP Server
olivierlp
olivierlpCommunity ManagerAnswer
Community Manager
April 2, 2026
Hi ​@CC_3911250,
Best regards,
Samarth Shelke
Olivier
olivierlp
Community Manager
April 2, 2026
Hi  ​@sashelke
but why 2 files? Why not a single file 90-app-Windchill-Auth.conf and add both blocks:
<LocationMatch "^.*servlet/(WindchillGW|WindchillAuthGW)/wt\.wrmf\.transport\.httptransport\.ReconnectedHttpURLCon(?:;[^/]*)?/.*$">
Require all denied
</LocationMatch>
Require all denied
</LocationMatch>
Olivier
olivierlp
Community Manager
April 2, 2026
Initially posted by ​@mmeadows-3 on March 30,2026
The articles were not written at the same time and are designed to be independent.  So, each article identifies a unique file name.  There is no reason to create two files.  In your combined file, ensure they are in the order defined by the articles (90 first and 91 second).  Also document these changes to make it easier to identify the source of the changes.  I created a single 90-app-Windchill-Auth.conf file.
# Security Patches
# 3/23/2026 https://www.ptc.com/en/support/article/CS466318
Require all denied
</LocationMatch>
# 3/28/2026 https://www.ptc.com/en/support/article/CS466866
Require all denied
</LocationMatch>
Olivier
