Customization - Java app listen to CHECKIN_COMPLETED event
  • March 13, 2013
  • 3 replies
  • 875 views
I want to perform some java actions at every checkin, does PTC offer some way to listen the CHECKIN_COMPLETED event to trigger those actions? I know the publisher does something like that and I want to do the same with java but I dont know how to do it...
Some guidance to start it would be greatly appreciated!
Warm Regards
Guilherme Rocha - Tech Consultant
PLM Solutions do Brasil
“A goal without a plan is just a wish.”
I guess you would be listening for "POST_CHECKIN" from WorkInProgressServiceEvent class. Check Windchill Java Doc at following link for this.
<windchill>/wt/clients/library/api/wt/vc/wip/WorkInProgressServiceEvent.html
grocha1-VisitorAuthor
Thank you very much for your answer! I will research on that!
Warm Regards
The customizer's guide shows an example listener program you can copy and
change for your needs. How to deploy is also discussed.
