DataUtility to show the discrete set values in a Multi Select Combobox
  • December 2, 2011
  • 800 views
Hi
I have an attribute for WTPart which has a discrete set constraint. I need to write a data utility to display those values in a multi select combobox.
Anybody has got any code which can retrieve the Discrete Set values of an attribute?
Hi
In Windchill 9.1 OOTB, if we have an attribute with a discrete set
constraint, by removing the Single Value Constraint, we can make an
attribute accept multiple values. In UI, it is shown in a funny way, with +
and - buttons (to confuse the user ?) .
I searched for the datautility which renders this UI, but couldnt find.
Praseeth M
