avillanueva
23-Emerald I
June 22, 2012
Default page when click on document details
  • June 22, 2012
  • 2 replies
  • 693 views
I believe in 9.1 the default when navigating to a document details page
is that it shows the iteration history. Can this be changed? Users
sometimes get confused and click on old content. How would this be
done?
Antonio,
In the Profile for your users you can de-select viewing of Iteration, Revision & Maturity history.
Mike Ibosh
Hello Antonio
wt_home\codebase\config\actions\DocumentManagement-actionmodels
you can see a configuration as below
<model name="third_level_nav_doc" defaultactionname="iterationHistory"&lt;br"/>defaultActionType="history">
<action name="documentStructure" type="object"/">
OOTB defaultActionName is pointing to "iterationHistory". By changing this
you can control the default section.
HTH
Thank you and have a great time.
Best Regards
Swamy Senthil
Principal Solutions Architect, Swasen Inc
swamy.senthil@swasen.com(Email); 909 800 8423(M); 973 324 2729(W); 866
908 6561(F);
