Delete Sub Sites
  • January 29, 2010
  • 6268 views
What is the best way to delete sub sites held within ProductPoint, as I've had a look at trying to delete the site, but there doesnt seem to be a delete Icon.
Hmm, discovered the same recently. Some sites I can delete (one of them contains 90% of all our data) en some don't (an empty one which I made for a test). I'm logged in with admin rights, so that can't be the problem.
At the first one I see an option "Delete this site".
And the second one doesn't...
Cor
To delete the site, you first need to :
1) delete the structure library, "proenginner documents" from the settings/structure library settings.
2) delete any other structure libraries
3) delete the product site
Note this you will be unable to delete the structure library if any files have been released, you may also have a problem is files have been moved between sites.
Unfortunately that doesn't work. Like I mentioned, there is no data in it, there never has been any data in it and there are no structury libraries in it.
Best regards,
Cor
