Deriving SQL by executing the IE task code
  • March 15, 2012
  • 2 replies
  • 1943 views
Hi All
Is there a way we can get hold of the underlying SQL by executing the IE task code and watch it to execute.
Any suggested tools or technicques?
The database is Oracle 11g.
Looking forward to your help
Thank you
Murugan
What is it exactly are you trying to accomplish? I have my little tips and tricks to extract data from the database so that way I can write my own reports, or resolve issues with the application without having to contact the painful support at PTC.
Hi Patrick Lee
There is a AS 400 program calls an intermediate Java program, which in turn executes an IE task on Windchill server to pull the information and gets the report. This program has been written for all the change objects in Windchill.
We need to build the SQL that executes on Windchill and pulls the same information as that of the program I stated above (as we wanted to do away with that old program). The program is built based on Workitems. Now, since the workitem are archived, we have to find an alternate way to make this SQL work without using workitem table
Can you help?
Thank you
Murugan
