Developing code in Workflow Template Administrator
  • July 16, 2013
  • 9 replies
  • 6259 views
I . . I'm a windchill starter user and i have skills in JAVA , now i'm trying to construct a Expression in Workflow Template Administrator and i need to get the PDF (Representation File) from a EPM Document received in a Promotion Request and copy that to a specific folder ...
I get this piece of code from internet but i get errors showed in bottom...
try{
QueryResult theQueryResult = MaturityHelper.service.getPromotionTargets(thePromotionNotice);
Versioned theVersioned = null ;
if (theQueryResult != null){
while(theQueryResult.hasMoreElements()){
theVersioned = (Versioned)theQueryResult.nextElement();
if (theVersioned instanceof EPMDocument) { ... }
catch(...){}
//primaryBusinessObject
QueryResult theQueryResult;
wt.maturity.PromotionNotice pn = (wt.maturity.PromotionNotice)primaryBusinessObject;
try{
theQueryResult = MaturityHelper.service.getPromotionTargets(pn);
System.out.println("IS A EPM DOCUMENT");
//É Preciso procurar o PDF AGORA.....
System.out.println("NOW GET THE PDF DOCUMENT");
}else{
System.out.println("THIS IS NOT AN EPM");
}catch(Exception e){
System.out.println("ERROR EXPORTING PDF: " + e.getMessage());
errorMsg = "ERROR EXPORTING PDF Promotion Request: " + e.getMessage();
Five errors reported in check Syntax..
1) WfExpression45853891.java:36: cannot find symbol
symbol : class QueryResult
2) WfExpression45853891.java:39: package MaturityHelper does not exist
3) WfExpression45853891.java:40: cannot find symbol
symbol : class Versioned
4) WfExpression45853891.java:43: cannot find symbol
5) WfExpression45853891.java:44: cannot find symbol
symbol : class EPMDocument
I need help here because and dont know all structure of Windchill API classes
Best answer by ybagul
Windchill needs FQN in expression robots for workflow templates. Use following to resolve your errors.
1) wt.fc.QueryResult
2) wt.maturity.MaturityHelper
3) wt.vc.Versioned
4) wt.vc.Versioned
5) wt.epm.EPMDocument
For Windchill JavaDoc, use following link on your 9.1 Windchill server (dont know for 10)
https://myserver.mycompany.com/Windchill/wt/clients/library/api/index.html
ybagul1-VisitorAnswer
3) wt.vc.Versioned
4) wt.vc.Versioned
July 17, 2013
Thank you Yogesh Bagul ! it's solved ..
But now i'm with dificult .. i need to know if the object in PBO is a DRW (Creo Drawing)
i have this:
if (theVersioned instanceof wt.epm.EPMDocument) {
myDoc = (wt.epm.EPMDocument)theVersioned;
System.out.println("TYPE OF DOC: " + myDoc.getDocType());
But i get CADDRAWING , so i can compare this with
if(myDoc.getDocType().toString().equals("CADDRAWING") ){
Or exist other way to do this ?
Other question is how can i get the representations of CADDRAWING ?
Because i want the list of Representations, verify if exist any representation in PDF format and after that copy the file to a share in other server. .
Regards !
I guess your validation for CADDRAWING is good enough. To get representations from EPMDocument, look at wt.content.ApplicationData class. You can check and then stream representation file to file share.
