Disable autonumbering for WTPart
  • November 30, 2012
  • 826 views
Friends,
The title says it all.....
I have modified the OIR to remove the autogenerate tag for WTPart OIR --> It did not work, since the create part screen still shows Partnumber <generated>
then I recreated the jars, and restarted the methodserver, but still the same result.
Am I missing something?
My requirement is pretty simple- Manual numbering for WTParts.
Thanks in advance for all replies.....
Ravin
GregoryPERASSO
Try to download the "composite" XML for your init rules at the context level you try to create your Part
If you're in a Product or Library, may be you have another init rule at Org or Site level that contain an autonumbering constraint for WTPart. And you inherit it ....
regards
Gregory
