Displaying more information from a list of attribute of an article
  • August 7, 2012
  • 2 replies
  • 1279 views
When defining a list of values for a attribute of an article, there is a string of all values separated by pipe character in the "Attributes and types manager".
This way produce a "Selection" list of all values.
My question is if there is any way to give more information when displaying this list, I mean if I have a list of 25 numerical values, I want to display a definition of the value during the selection process by a small yellow popup, typically with the "title=" HTML tag of the "<option>" tag.
Is this possible with Winchill 9.1 ?
Thanks for answers.
Best answer by cguillod
After contact with PTC support, this feature is not possible in Windchill.
cguillod1-VisitorAuthorAnswer
22-Sapphire I
September 14, 2012
It would be great to be able to provide info in a tooltip.
Our only current workaround is to provide a link on many create / edit wizard pages to a chart (in a document in Windchill) that lists each choice and provides explanations for each. This has worked out reasonably well.
