Apr 12, 2024 12:45 PM UTC
Does Inventor Worker machine need GPU
Is it required to have a GPU to publish using the AUTODESK Inventor worker? For huge assemblies does it make any difference?
rhartAnswer
Apr 15, 2024 9:35 AM UTC
I've tried Inventor workers with a GPU and without, I monitored the GPU performance while the worker was running as it basically just sat there doing nothing. There are also graphics hardware config options in Inventor Pro which set whether GPU or CPU is used and these don't affect the worker. The best results performance-wise was from Apprentice mode (where you use Inventor Server to process the publish jobs rather than Inventor Pro)
Apprentice mode has challenges too though, it can't publish drawings to PDF and fails on assembly models if any of the components contain embedded images.
Apr 15, 2024 3:20 AM UTC
I'd recommend reviewing the requirements from AUTODESK. I think this may be helpful:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirements-for-Autodesk-Inventor-2024.html
Apr 15, 2024 7:52 AM UTC
GPU is needed for any visualization worker, even though the application (Inventor in this case) will be opened in a non- Visual graphic mode (Background).
Cheers
Hari
HelesicPetr
Apr 15, 2024 8:34 AM UTC
@Hari_Vara I am not sure if your opinion is true.
GPU is not needed on the server where the worker is installed because all work is done in a classic system CPU.
GPU is used only and only for showing the environment on a display. If you connect to the server remotely your local GPU is used to show the system.
PetrH
Apr 15, 2024 8:46 AM UTC
I was thinking that in case of Interference Detection Jobs (which is quite common in Industrial Equipments, Machinery, Auto, Aero), then it requires the GPU. Otherwise you are right.
Best Regards
Hari
rhart16-PearlAnswer
Emeritus
Apr 17, 2024 2:45 PM UTC
Hi @AP_10483126
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
