Download ProE files
  • January 17, 2011
  • 10 replies
  • 2916 views
Hi all,
Hopefully this is an easy question. In 9.1 M050 when I selected download conten it allowed me to download the ProE models directly. We upgraded to 9.1 M060 and now when I select to download content it downloads the pha file which can open directly in ProE but it won't allow me to save the file directly as a native ProE file as before. I thought it was maybe a preference but I haven't been able to find it yet. Anybody have any ideas?
Brian
Brian,
This was done by PTC to help control the content. We put a ticket it and got this straight from PTC. We were not real happy with hearing this as there are many times we just wanted the content without having to open it up in the tool, back it up and so on. I would like to know if anyone else is not happy with this change and maybe we can get it reverted back to pre-9.1 M060 functionality, or at least get it as a preference.
Tyler
I would caution you against downloading ProE files directly from PDMLink without using a linked workspace in ProE.
Here's the problem. You check in a file, it goes through a release process and becomes a released file. (Our drawings show the state of the file in PDMlink on the format.) What has happened in the data base is some meta-data has been changed indicating the state of the file. However, the ProE file has not been changed at all. If you download the file without using a linked workspace, the parameters in the file never get updated with the new state and version. So if you compare the state/version with what the database shows, you will get a mismatch even though the file is "the same". A recipe for confusion.
David Haigh
avillanueva
23-Emerald I
January 19, 2011
Do not forget about rename events. The relations internal to the file
get altered as the file is coming out to the workspace.
Brian,
After reading your Email on Download ProE files, I had the Etrage
Development group check Plot Service for Windchill (PSW) with Windchill 9.1
M060 for your issue.
They advise me that PSW does download models from Windchill and updates the
parameters with the new state and version. PSW can do this in three
operating modes.
1. The first is to automatically monitor Windchill and process objects
when there has been a Lifecycle or Revision change or at Check-in.
2. The second is a batch mode where PSW will process all models
identified in a text file list.
3. The third is through an On-Demand mode where a user can search for
models and execute requests in Windchill for required drawings, parts or
assemblies.
PSW is available for evaluation in your environment or I can arrange a Web
demonstration for you.
If you have any questions, please contact me.
Best Regards,
Ron Zabilski
Director of Sales & Marketing
Etrage LLC
I do know that Najanaja.com has developed the download tool that uses the classes of the collector to gather all your ProE files based on a configuration to place them all in a zipped folder called ProE. I beleive that Psion Teklogix Inc. uses this tool. You can either select actions of the object or the top table report for either part or EPM. For wtpart, it would create folders of each part and place the WTDocuments in that folder. All ProE files would be placed in a global ProE folder. The entire package would be zipped up so you can pull it all out of Windchill. It was also based on your access controls of the information.
Gentlemen,
We have a product that does this very easily and it uses all of the proe
components silently.
Timothy J. Weatherford
TWeatherford, Inc.
3148 Beach Blvd
Cicero, IN 46034
<">http://www.tweatherford.com> www.tweatherford.com <
<">http://www.tweatherford.com> ">http://www.tweatherford.com>
866 936-2756 x 301
317 710 9747 mbl
419 821-5765 fax
Please visit our new website to find more information regarding our company,
products and services!
"If you continue to ignore PLM, you will learn about it from your biggest
competitor"
Tyler is right on the moneythat PTC removed this at M060 and I believe the main reason is what David mentioned about the issuesthat happenwhen a workspace is not used. Customers that were using this old functionalityto get AutoCAD files that had no references are really out of luck since these files were not impacted when a workspace was not used.
You can check out linkAccess from Fishbowl to do this and more. linkAccess can work in several ways...Trigger mode, Web Interactive, Batch, and more.
It is a great application to allow departments like purchasing to easily and securely access files in the format they want when they want them...and they don't have to bother engineering.
<u>www.fishbowlsolutions.com/</u>
Best regards,
Rick Passolt
rpassolt@fishbowlsolutions.com
Okay, I'll be more blunt on this one. J This also affect users of
CATIA.and other WGM's.
Hey PTC, I know you are watching, seems to me like you are colluding with
partners so customers have to pay more for what they are supposed to do out
of the box?!?!?
Instead of fixing the problem in the first place, let's make it more
difficult for people to do their job so that the employees supporting the
tool have to hear more crap from engineering and manufacturing!! Why not
practice some good CRM and make a flexible fix? i.e. install this patch if
this concerns you and in future releases we'll improve the built in
flexibility.
Gee, it makes perfect sense to me to say hey, they are not downloading in a
workspace, they are not a designer, they are only downloading. How about
apply a fix that to this problem that says if it's a released object, or in
a list of lifecycle states specified as a PREFERENCE, let us download it
still.
Let the customer choose when this issue really matters?
Personally, (because I know how) , am just going to restore the M050
functionality to M060. Problem solved. In fact, might just be easier to
explain it to those who want it back. Or, we could make decisions like with
Microsoft Windows.stick to XP, bypass Vista, and goto Windows 7 (M050 and
not go to M060 in this case)
Whoever made such a dumb decision to take away functionality like this so
quietly without providing some kind of preference or elicit feedback should
explain themselves!!!
We use the download of the native Pro-e files to work with Esprit milling/turning. We are also not happy that this function got changed.
Bernard Wielfaert
LVD Company nv
Bernard,
If you are having issues downloading native Pro/ENGINEER files, please
consider Etrage's PSW - Plot Service for Windchill.
PSW can download native Pro/ENGINEER drawing, assemblies and parts as well
as their associated models in three modes of operation.
1. Monitoring Windchill for an event such as Revision or Lifecycle
2. On-Demand, where users can search and select models of interest for
processing.
3. Batch, where users can submit a text file list of models for
processing by PSW.
If you are interested, I can send you more information about PSW. I can
also arrange a Web demonstration.
Best Regards,
Ron Zabilski
Etrage LLC
