Driven Enumerations
  • January 3, 2013
  • 2 replies
  • 1819 views
Hello again, I was wondering if now at 10.0 or 10.1 is possible to associate driven enumerations for attributes.
I mean, each attribute associated to a enumerated value list and at object creation, a selection made on the first attribute drives the possible values within the next combo.
If possible, how do I do it?
Regards
When you create an idea for this feature, I will vote for it.
Regards, Hugo.
try for Linked List Component and control the values using Handlers.
This can be done from javascript also. ie from the object creation page write a script to read the value of attribute on ''onchange'' event and control the other atribute with respect to that.
Regards
Gangadharan.N
Can you please elaborate on the solution you mentioned.
Dhanashri / Emyr,
Did you get anything like that?
Can you share the logic?
