Duplicate entries in the Change Summery table of a Change Notice
  • August 7, 2024
  • 4 replies
  • 1255 views
Hi Everyone,
We have requirement that if someone select the REWORK voting then we have customised drop-down where we get the option to select resulting items for REWOK and it creates the new REWORK task so what happened when we create the  New REWORK task with same affected and resulting item
That time in Change Summary we get duplicate objects so do we have any way how we can avoid duplication in Change Summary
Best answer by @_1647
Yes that is because of new REWORK task and affected and resulting items which are in ne wtask ,
So, what I did after creating new REWORK task  I removed objects from old task using code only but that approach they don't want because old task and objects should be there for end user reference
  • So I need another approach like how can we create new filter or how we can customise CN summary table builder to get distinct data.
  • We can use filter there because even after creating new task we are not changing name of that task so we can use that as our key to filter data in table
Can you provide a data-sanitized screen shot?
@_164713-AquamarineAuthor
Please refer attached snap of CN summary where part *001 with same version added in table for 2 different tasks as an affected and resulting objects.
And we want distinct data in a table.
@_164713-AquamarineAuthorAnswer
