Easiest Way to Report on "Checked out Objects"?
  • December 4, 2012
  • 4 replies
  • 1509 views
Doing an update and need a report or method to show all checked out objects and their owner if possible. I'm sure I can create a custom report for this (WC10) but wondering if there is an easier method out there.
[cid:image001.gif@01CDD1E9.DF409830]
Steve Vinyard
Application Engineer
Phone: 1.800.800.1714 ext 3126
-<">mailto:-> / www.tristar.com
The attached QML ended up being real easy. If you don't already have this feel free. It works well.
[cid:image001.gif@01CDD1FD.64F28980]
Steve Vinyard
You can also change the EPMDocument table to Revision Controlled to get all Checked out Objects (CADs, Parts and Docs).
Liu
Jim
attached is a report with user names
Regards Darren
Thanks Darren,
I figured out my problem using Steve's report. Pebkac:Didn't select all fields when running the report. Doh!
Thanks again!
