8-Gravel
Mar 30, 2023 4:57 PM UTC
ECRs completed but stuck in the system!!!
How do you identify ECRs stuck in Implementation but have the ECN Resolved?
Mar 30, 2023 5:55 PM UTC
You can create a report that shows all Completed ECN's where the linked ECR is not.
Naim238-GravelAuthor
8-Gravel
Mar 30, 2023 6:15 PM UTC
Hi SteveG,
How would you do that?
Naim
Mar 30, 2023 6:18 PM UTC
Can you log in as the administrator?  If not then you would have to talk to whomever that is.  If you are the admin then you need to go to the Utilities.  The "Team Administration" is listed there.
avillanueva
23-Emerald II
Mar 30, 2023 7:13 PM UTC
See attached, you might have to adjust states to your process. You can also look for CNs that have a resolution date and the CR does not. This is a QML of my check.
avillanueva
23-Emerald II
Mar 31, 2023 5:29 PM UTC
That QML does not work, bad join. Try this.
MarcoTosin
Mar 31, 2023 7:07 AM UTC
You can also take a look at this article
Understanding Change Management objects and their relations in Windchill PDMLink
In another community discussion I attached the more complex report we use in the company.
It links ECR (Change Request), ECN (Change Notice) ECT (Implementation Task) and also Workflow Process.
Marco
8-Gravel
Apr 4, 2023 11:58 AM UTC
Hello;
This issue is unresolved; I'm working with my Windchill admin to try these proposed solutions.
Kudos to ALL of you for trying to help!!!
Naim
