EPMParameterValue error in windo log after migration
  • March 24, 2011
  • 2 replies
  • 733 views
After migrating everything (including filetransfer) from Intralink 3.4 M030 to 9.1 M060, I ran windu to verify the family tables.
All was well except as follows:
Thu 3/24/11 08:16:43: ERROR|wt.epm.familytable.EPMParameterValue|5552158|20270
The 2nd line is repeated 1061 times, with different values for the 7-digit number (ex: 5552158)
Is this serious?
Any advice?
Gerry.
20-Turquoise
March 24, 2011
> Thu 3/24/11 08:16:43: COMMENT|wt.epm.familytable.EPMParameterValue [EPMParameterValue] has 1061 errors
> Is this serious?
> Any advice?
From page 7-11 (151) of the Data Migration Admin Guide (Windchill 9.1 April 2010) step 5 says this:
5. If any problems are reported in the log file, open a call with PTC Workgroup Manager and send the report to <windchill loadpoint="> \logs\windu.
After you open the call they will send you a healing script (most likely epm-heal-tool_X12.zip) along with instructions on how to run it.
> Gerry.
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
March 24, 2011
Thanks to all that replied.
I was aware of the documention's instructions to send this to PTC.
I just wanted to hear from the exploder before I proceeded.
I submited a call to PTC, and they responded very quickly.
They sent me an sql script which fixed/deleted the bad records in a matter of seconds.
Gerry
