Error: invalid parameter column definition
  • July 2, 2012
  • 2406 views
We recently migrated from Intralink 3.4/WF3 to PDMLink10.0/CreoElements(WF5) A user checked out an existing assembly drawing, added another instance to the assembly family table, and is now unable to check it in. He gets this error: invalid parameter column definition. Does anyone have any helpful ideas?
Thank you,
Donna
Refer following KB docs and/or contact PTC Technical Support
  1. TAN 138174: https://www.ptc.com/appserver/cs/view/solution.jsp?n=138174
  2. TAN 139056: https://www.ptc.com/appserver/cs/view/solution.jsp?n=139056
dandersen1-VisitorAuthor
Thank you Dinesh Tondy. I believe the second doc is the info I need.
