Error messages in Background Method Server log
  • February 19, 2014
  • 0 replies
  • 1219 views
Does anyone have an idea what is causing these error messages in the Background Method Server log? (7 to 8 log files of 9MB are created per minute)
We are using Windchill 10M030.
Kr,
Sven
2014-02-19 10:38:59,887 ERROR [commonProcessQueue.PollingThread] wt.queue.ProcessingQueue.commonProcessQueue Administrator - Exception in doWait()
wt.pom.DatastoreException: A SQL error has occurred. Database system message follows:
Nested exception is: wt.pom.ConnectionException
at wt.pom.POMHandler.getConnection(POMHandler.java:87)
at wt.method.MethodContext.getConnection(MethodContext.java:2058)
at wt.pom.PersistentObjectManager.getUserConnection(PersistentObjectManager.java:322)
at wt.pom.Transaction.start(Transaction.java:535)
at wt.queue.WtQueueThread.doWait(WtQueueThread.java:308)
at wt.queue.PollingQueueThread.run(PollingQueueThread.java:138)
2014-02-19 10:38:59,887 ERROR [wt.router.5.1.PollingThread] wt.queue.ProcessingQueue.wt.router.5.1 Administrator - Exception in doWait()
2014-02-19 10:38:59,887 ERROR [wt.router.5.2.PollingThread] wt.queue.ProcessingQueue.wt.router.5.2 Administrator - Exception in runnable()
wt.util.WTException: wt.pom.DatastoreException: A SQL error has occurred. Database system message follows:
Nested exception is: wt.pom.DatastoreException: A SQL error has occurred. Database system message follows:
at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1099)
at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1015)
at wt.fc.StandardPersistenceManager._query(StandardPersistenceManager.java:1829)
at wt.fc.StandardPersistenceManager.query(StandardPersistenceManager.java:1368)
at wt.fc.StandardPersistenceManager.query(StandardPersistenceManager.java:1050)
at wt.queue.QueueMonitorHelper.getWtQueue(QueueMonitorHelper.java:380)
at wt.queue.QueueMonitorHelper.getWtQueue(QueueMonitorHelper.java:306)
at wt.queue.WtQueueThread.runnable(WtQueueThread.java:251)
at wt.queue.PollingQueueThread.run(PollingQueueThread.java:95)
2014-02-19 10:38:59,887 INFO [forumEventPropogationQueue.PoolQueue] wt.system.out Administrator - at wt.queue.ProcessingQueue.getReadyEntriesOracle(ProcessingQueue.java:632)
2014-02-19 10:38:59,887 ERROR [RDImportExecutorQueue.PollingThread] wt.queue.ProcessingQueue.RDImportExecutorQueue Administrator - Exception in doWait()
2014-02-19 10:38:59,887 ERROR [PublisherQueuePRINT1.PollingThread] wt.queue.ProcessingQueue.PublisherQueuePRINT1 Administrator - Exception in runnable()
2014-02-19 10:38:59,887 ERROR [PublisherQueueCLASH1.PollingThread] wt.queue.ProcessingQueue.PublisherQueueCLASH1 Administrator - Exception in runnable()
2014-02-19 10:38:59,887 ERROR [NotificationQueue.PollingThread] wt.queue.ProcessingQueue.NotificationQueue Administrator - Exception in doWait()
2014-02-19 10:38:59,887 ERROR [CtmdRecomputeMembershipQueue.PollingThread] wt.queue.ProcessingQueue.CtmdRecomputeMembershipQueue Administrator - Exception in doWait()
