Sep 4, 2025 11:01 AM UTC
Error while creating Context
I am using PTC Pro/Intralink Release 11.1 and Datecode with CPS M020-CPS13
While creating a product, getting below error:
Type Identifier "WCTYPE|wt.change2.WTChangeReview|wt.change2.PeerReview" cannot be found. See the Windchill Business Administrator's Guide for further information.
Here are the errors that I faced
    avillanueva
    23-Emerald II
    Sep 10, 2025 2:34 PM UTC
    Make a new template and make the modifications in that template. Its just an XML file.
    Sep 4, 2025 11:11 AM UTC
    Followed PTC Article - CS391160, but issue still exists
    avillanueva
    23-Emerald II
    Sep 4, 2025 11:44 AM UTC
    Are you using a specific or custom product/library template? You can download that (its XML) and see if its looking for that object type. Does that object type exist in your Type Administrator at the site level?
    Sep 4, 2025 2:49 PM UTC
    I looked over the product template XML and its looking for the object type. On the Type and Attribute end, initially the type is not there but i created one and even after that as well, the issue persists.
    avillanueva
    23-Emerald II
    Sep 5, 2025 2:29 PM UTC
    The Peer Review object should exist in your system. The fact that its not is the issue. I do not think this is something you can just create. Noting you called this system Pro/Intralink 11.1. Intralink was retired long ago, you mean Windchill right?
    https://www.ptc.com/en/support/article/CS394902?source=search - Possibly deleted by mistake?
    You should be able to remove the ACLs in the product template xml and reupload so it does not called out a reference for this but I would be concerned at why this is missing in the first place.
