Error while invoking JConsole Remotely as well as on the server .
Hi Gurus,
We are facing a challenge in invoking the JConsole Remortely as well as on the server.We have the system on 9.1_M050. Does anybody have an idea what happening wrong here?
JConsole Remotely:-
1) Set the following properties in site.xconf and propagate.
<property name="wt.manager.cmd.common.jmx.args" overridable="true"</p">
targetFile="wt.properties"
value="-Dcom.sun.management.jmxremote"/>
<property name="-Djmx.remote.protocol.provider.pkgs" overridable="true"</p">
value="wt.jmx.remote.protocol"/>
<property name="-Dcom.sun.management.jmxremote.authenticate" overridable="true"</p">
value="false"/>
<property name="-Dcom.sun.management.jmxremote.ssl" overridable="true"</p">
value="false"/>
<property name="-Dcom.sun.management.jmxremote.ssl.need.client.auth" overridable="true"</p">
value="false"/>
<property name="wt.manager.cmd.ServerManager.jmx.args" overridable="true"</p">
value="-Dwt.jmx.rmi.port=6049"/>
2) Invoke JConsole from Start--> Run --> JCosole
3) Add the hoste name : port , userID /Password and say connect.
The Result is “could not connect to the Server”.
Invoking the JConsole on the Server.
1) Open the windchill shell and type "windchill wt.util.jmx.SMJconsole"
2) It returns an error
Exception in thread 'main' java.lang.NullPointException
at wt.util.jmx.SMJconsole.main(SMJconsole.java:38)
Any pointers would be highly appreciated.
Mayur
