Export from Windchill Directory Server
  • February 20, 2010
  • 4 replies
  • 1017 views
Anybody know how to export the Enterprise and Administrativepeople node from the Windchill Directory Server?
I could do this before in Aphelion.
See "Export LDIF" in the WindchillDS Control Panel.
I very highly recommend the Apache Directory Studio to browse and directory
server including Windchill's.
you might want to go through the below documentation from openDS. One of the
commands is for exporting data below a specifies node. I have not tested
exported from a node.
Rohan Kalbhor
Email:- <->
Thanks for the answers.
The short answer is that you cannot export a certain branch from the
Windchill Directory Server UI.
You can do it via a command line.
You can also connect Aphelion Browser to Windchill Directory Server session
and export different branches.
Herb Miller
TWeatherford, Inc.
herbm@tweatherford.com
3148 Beach Blvd
Cicero, IN 46034
www.tweatherford.com
866 936-2756 x 305
502 552-7179 mbl
419 821-5765 fax
Read our latest newsletter by clicking here
"If you continue to ignore PLM, you will learn about it from your biggest
competitor"
