Exporting PDF's from PDMLink
  • March 2, 2011
  • 15 replies
  • 4460 views
We have PDMLink setup so the drawings are published as PDF's instead of ProductView files. Now we would like to export all PDF's to harddrive. Does anyone know how to accomplish this?
I have tried the Import/Export utillity and also Export from workspace without success (the PDF's are not included in the export).
PDMLink 9.1 and Pro/ENGINEER Wildfire 5.0
Best Regards,
Hans Berg
Yep, lots of time spent...ha...ha
http://www.datajett.com/windchill/wc_dev/saverep/saverep_readme.txt
http://www.datajett.com/windchill/wc_dev/saverep/dlRep_REPSAVEAS.zip
There are 2 methods for this tool:
1) Actions from Windchill DRW details page or product/library page.
2) Command line where DRW number is an argument.
But we need Hans to respond on whether he needs one at a time or all DRW's in his system.
Now is that all or Released state only, etc.
I could easily create a 2nd java program to cycle through all or Released state, or all DRW's of a specific state (maybe other than Released). But I want to hear from Hans on what he really wants.
If he wants one at a time, then the program linked above, might cover his needs.
If he wants all DRWS, all Released or other state, I can write that code, but I dont want to break out the vmware, if the existing works for him.
I have existing code to cycle through all epmdocs & then DRW's. I could insert that into a new version of dlRep_main, so it then output all DRW associated PDFs &/or PLT's if wanted.
It also wants an argument for download folder, so you could do this nightly & write to a new date stamped folder each night.
But I dont want to write this code, then Hans never comes back for it. Wasted effort.
Unless some one else here actually uses the original & wants the other created & will use it.
If I do this, my original intent will be for a State (Released) to be an argument on the command line, in case others want a different or multiple states.
Now lets see if anyone is watching over the weekend, because I might be on the road early next week, to the next job...yeahhhh.
Let me know.
Larry Jett
cadjett@aol.com;datajett@aol.com
where datajett@aol.com mail gets noticed quicker.
Just thought of something. If you set the drawing number argument to % (wildcard), it might download all epmdocs or just drawings with associations. You might try to %.drw or %.DRW.
I cant recall if have the dlRep_main to cycle through all epmdocs that it finds that match drawing number argument or only cycle through once.
command line would be:
java ext.dlRep_main c:\temp % pdf
or
java ext.dlRep_main c:\temp %.drw pdf
I will try to test later, but my slow computer & vmware hog are making things rough.
Let me know if anybody tries.
L Jett
In Reply to keith schmitt:
have you tried this?
http://portal.ptcuser.org/p/fo/st/thread=42720
Thats shows that memory does go with old age. Even my readme on this, shows it should do all epmdocs:
2 things on this:<br /><br />1)<br /><br />I did find that the command line class will run the wildcard alone (%) &amp; will grab all DRW epmdocs &amp; download the associated PDF or PLT.<br /><br />java ext.dlRep_main &lt;download folder="&gt; &lt;number search=" string="&gt; &lt;content type="&gt;<br /><br />java ext.dlRep_main C:\TEMP % pdf<br /><br />You can use plt instead here, if desired.<br /><br />So if the original request of this post was to download all DRW pdf's, it should do that.<br /><br />2)<br /><br />Some one emailed me &amp; asked that I write one to only download epmdoc DRW's in RELEASED state.<br /><br />AbraCadabra - *&amp;^!@%$#$<br /><br />http://www.datajett.com/windchill/wc_dev/dlRep_REPSAVEAS/dlRep_Rel.zip<br /><br />java ext.dlRep_Rel_main &lt;download folder="&gt; &lt;number search=" string="&gt; &lt;content type="&gt;<br /><br />java ext.dlRep_Rel_main C:\TEMP % pdf<br /><br />You can use plt instead here also, if desired.<br /><br />After dealing with theslow laptop &amp; hog vmware, I was able to test &amp; write the new code.<br /><br />I wanted to write it to where any LC State could be entered as last argument (RELEASED, PRODUCTION, PRE-RELEASED, etc), but I only had one request &amp; was tired of the vmware &amp; slow activity there, to spend the extra time to write additional code.<br /><br />Along with the fact that not many will want other than RELEASED. But if you dont want LC State control &amp; want to download all epmdoc PDF's/PLT's, the original program does that.<br /><br />If some one does want PRODUCTION, instead of RELEASED, then I can write ot later &amp;/or just find/replace in the java source included in the above linked zip.<br /><br />L Jett<br />cadjett@aol.com;datajett@aol.com
hansberg1-VisitorAuthor
Hi All,
... and thanks for all the replies! It was so massive response so I haven't been able to go through all information.
I will go through all tips, ideas and solutions over the next week or so and I will then post the solution that resolved my issue.
Thanks again.
Hans Berg
I will test this. I need to see released PDFs only in a folder.
