Expression to Determine the Number of Participants in a Role
  • November 9, 2011
  • 11 replies
  • 4217 views
Does anyone know an expression which picks up the number of participants in a particular role?
For example, using a conditional node to determine if enough principals are in Promotion Approvers role?
Toby
Best answer by MatthewKnight
You have to use full package names for anything outside of java.lang.
result = "ERROR";
try {
if (primaryBusinessObject instanceof wt.team.TeamManaged) {
wt.team.Team team = wt.team.TeamHelper.service.getTeam((wt.team.TeamManaged) primaryBusinessObject);
Role role = Role.toRole("APPROVER");
int count = 0;
Enumeration<?> principals = team.getPrincipalTarget(role);
while (principals.hasMoreElements()) {
wt.org.WTPrincipalReference next = (wt.org.WTPrincipalReference) principals.nextElement();
if (next != null) {
count++;
if (count > 1) {
result = "CONTINUE";
} catch (Exception e) {
e.printStackTrace();
There are several ways you could do it. Here's one approach that does not expand group participants
Team team = .......
int count = 0;
while(principals.hasMoreElements()) {
WTPrincipalReference next = (WTPrincipalReference)principals.nextElement();
if(next != null) {
count++;
} else {
System.out.println("null");
System.out.println("count: " + count);
Thanks.
For the team what should I be using?
The context team, team template or team instance? And if it is the latter then how would I get an expression for it?
Toby
I would assume you want to check the primaryBusinessObject's team. That's more than likely going to be wt.team.Team.
if(primaryBusinessObject instanceof TeamManaged) {
Team team = TeamHelper.service.getTeam((TeamManaged)primaryBusinessObject);
FYI, from my perspective:
Team and TeamTemplate are designed pretty much identical to each other.
ContainerTeam(s) are much different and several of the WTRoleHolder2 APIs do not work for ContainerTeam. ContainerTeam uses WTGroups to represent its Role's.
I tried it all and it came up with an error..
When I check the syntax in the conditional it says:
Checking Syntax...
/apps/ptc/Windchill_9.1/Windchill/tmp/WfExpression_htorgadmin-toby.java:16: '{' expected
public class WfExpression_htorgadmin-toby {
1 error
Syntax check complete.
The thing is this comes up even if the conditional block is empty... What am I missing?..
The code I am trying to use is:
result = ERROR;
int count = 0;
if(next != null) {
count++;
} else {
if(count<2) {
result = ERROR;
} else {
result = CONTINUE;
Correction it is now saying:
symbol : class TeamManaged
/apps/ptc/Windchill_9.1/Windchill/tmp/WfExpression8879749.java:34: package TeamHelper does not exist
/apps/ptc/Windchill_9.1/Windchill/tmp/WfExpression8879749.java:37: cannot find symbol
symbol : class Role
symbol : variable Role
/apps/ptc/Windchill_9.1/Windchill/tmp/WfExpression8879749.java:40: cannot find symbol
symbol : class Enumeration
symbol : variable team
Enumeration<?> principalsSyntax check complete.
Even though it had previously said there was no problem other than the one mentioned above.
result = "ERROR";
try {
int count = 0;
if (next != null) {
count++;
if (count > 1) {
Works like a charm. Thank you very much!
One last quick thing, do you know how I would apply the same code to the change admin III role? I've tried replacing "APPROVER" with "CHANGE ADMIN III" and "CHANGE_ADMIN_III". Neither worked..
"CHANGE ADMINISTRATOR III"
Roles are defined in RoleRB.rbInfo. It should be under <wchome>/src/wt/project
