EXTERNAL: Create EPMDocument using WC API
  • March 29, 2012
  • 0 replies
  • 486 views
Thanks you all for the leads, I will investigate on this.
Sincerely,
Thibault Magné
Le 29 mars 2012 14:48, Rosato, Chris <-> a écrit :
> If you copy, don’t you run into the possibility of accidentally not
> changing a value that gets carried over to the new doc? ****
> I wrote a note loader, which is an EPMDoc, and it’s pretty simple. I used
> the same new you had, then just set the TypeDefinitionReference, Series,
> CageCode/Org, Version, Iteration, Container, Description, Folder,
> LifeCycle, TeamTemplate, and State – along with any required IBA’s. For
> quite a few of our loaders, we use VersionControlHelper.service.insertNode
> to persist because we want the default insert behavior on any new version.
> I can’t remember which sets were required by the system, and which were
> required by us, but it gives you an idea of what is needed. ****
> Thanks****
> Chris****
> *From:* David DeMay [
