FolderHelper.assignFolderByReference
  • September 11, 2013
  • 15 replies
  • 8623 views
Hi All,
Anybody used FolderHelper.assignFolderByReference(part, oRef); to move objects from one container to another? Please help with the usage. I couldn't find a way to use this piece of code properly.
Wasim
Best answer by ManikandanVelay
Wasim
  1. If want to call any class in Workflow you should give fully qualified class name. for example: WTContainer -----> wt.inf.container.WTContainer
  2. doc.getContainer() will get container of your PBO
  3. For getting container by Name you have to write some QuerySpec for that.
  4. In case, If getting in situation where you need to Bulk of codes in Workflow ,better write your code into one java class file and call the same from Workflow Expression
Paste this two lines of code in workflow
wt.part.WTPart pbo =(wt.part.WTPart)primaryBusinessObject;
ext.CustomWTPartMover.PartMover(pbo ,"GOLF_CART ","Manufacturing");
//Here GOLF_CART Target product Name & Manufacturing is my folder Name inside Target product
This my Java class called in workflow
package ext;
import wt.dataops.containermove.ContainerMoveHelper;
import wt.fc.PersistenceHelper;
import wt.fc.QueryResult;
import wt.fc.collections.WTValuedHashMap;
import wt.folder.Folder;
import wt.folder.FolderHelper;
import wt.inf.container.WTContainer;
import wt.inf.container.WTContainerRef;
import wt.method.RemoteAccess;
import wt.part.WTPart;
import wt.pdmlink.PDMLinkProduct;
import wt.pds.StatementSpec;
import wt.query.QuerySpec;
import wt.query.SearchCondition;
import wt.util.WTException;
public class CustomWTPartMover implements RemoteAccess{
public static void PartMover(WTPart part,String ContainerName,String location)
try {
WTContainer cont=getMyProduct(ContainerName);
WTContainerRef containerRef = WTContainerRef.newWTContainerRef(cont);
Folder folder = FolderHelper.service.getFolder("/Default/"+location, containerRef);
WTValuedHashMap map = new WTValuedHashMap();
map.put(part,folder);
ContainerMoveHelper.service.moveAllVersions(map);
catch (WTException e) {
e.printStackTrace();
public static PDMLinkProduct getMyProduct(String ContainerName)
PDMLinkProduct product = null;
try {
QuerySpec qs = new QuerySpec(PDMLinkProduct.class);
qs.appendWhere(
new SearchCondition(PDMLinkProduct.class,
PDMLinkProduct.NAME, SearchCondition.EQUAL,
ContainerName), new int[] { 0 });
QueryResult qr;
qr = PersistenceHelper.manager.find((StatementSpec) qs);
while (qr.hasMoreElements()) {
product = (PDMLinkProduct) qr.nextElement();
} catch (WTException e) {
return product;
Hello!
I have not tried this but maybe you can try the below code instead?
WTPart part = getPart("name");
SubFolder folder = getSubFolder("libraryName", "folderPath");
try{
FolderHelper.assignLocation(part, folder);
}catch(Exception e){
I know the API is deprecated in Windchill 10 but there are some other similar methods there you can use that will probably do the same.
Best regards,
Peter
Thanks a lot Peter. I'll give it a try and will let you know how it works.
Wasim,
If you want to move objects then you better use below API
wt.dataops.containermove.ContainerMoveHelper.service.moveAllVersions(map);
// //////// MOVE OBJECTS /////////
This way, You will be able to move objects from library to product or vice versa.
Amit.
Hi Amit,
Thanks for your prompt response. Do you have an example code or something which could tell me how to use it?? I'd really appreciate that.
Wasim
Wasim
Here to go
public static void myCustomMover(String docNumber)
try {
WTDocument doc=getWTDoc(docNumber);
WTContainer cont=doc.getContainer();//you give different container also
String location="MyFolder//Documents/";
map.put(doc,folder);
Thanks & Regards
Manikandan
