Getting Workflow process variables
  • May 19, 2010
  • 952 views
Does anyone have a workflow code snip-it that from the change order process, will get a related change activity process variable value? In the CO process, I can get the associated change activities, but I need to get the value of a variable from that change activity. Any help would be much appreciated.
Mike
Hi Mike
You could try something as below.
public static Object getProcessVariable(Object obj, String wfvariable) {
Enumeration processEnum = null;
Object wfVar = null;
try {
// getAssociatedProcesses(Persistable
persistable, WfState wfstate, WTContainerRef wtcontainerref)
processEnum = WfEngineHelper.service.getAssociatedProcesses((Persistable)
obj,null,null);
while (processEnum.hasMoreElements()) {
// get the wfprocess
WfProcess wfprocess =
(WfProcess) processEnum.nextElement();
// get the processData
ProcessData processData =
wfprocess.getContext();
wfVar = (Object)
processData.getValue(wfvariable);
if (wfVar != null) break;
} catch (WTException e) {
e.printStackTrace();
return wfVar;
Thank you and have a great time.
Best Regards
Swamy Senthil
Principal Solutions Architect
973 216 0456(M); 973 324 2729(W); 866 908 6561(F)
Work Email: swamy.senthil@swasen.com
LinkedIn Profile:
