Grant ECN Create privs to a role in the ECR workflow
  • January 28, 2011
  • 0 replies
  • 35 views
Need to do this only in the workflow. In OOTB ECN workflow, the person tasked with creating an ECN is the CA2...this is to over arching in a larger workflow as I am implementing Change Notice Revise abilities but need to limit WHEN that can happen...hence I need to not have a full Change Admin as the creator. I also can't do the edits in the Policy admin as there are many many products already.
So, in the ECR workflow whomever I send the "Create Notice Task" needs to have permission to create an ECN...via the workflow. I can give workflow persmissions based on the PBO currently but don't have the knowledge of how to grant them to a different object.
Ideas?
[cid:image001.gif@01CBBECC.EAAE04F0]
Steve Vinyard
Application Engineer
Phone: 503-502-1370 / Fax: (800) 800-1714 Ext: 3126
-<">mailto:-> / www.tristar.com
