How and why I should use WinDU / WinRU?
  • September 30, 2012
  • 3 replies
  • 4964 views
Hello everyone,
I would like to know How and why to use WinDU and WinRU? I understand you would want to use it before an upgrade, but how about monthly maintenance? I would think that it does a great job of scanning the system and looking for issues. I looked for some decent how-to's but didn't find any. Using it is not rocket science at all. What I really am after here is a good explanation of the use cases and then after it is ran do I then execute WinRU? Do I run it on each node of the instance if it is a clustered install or is it ran once for the whole system?
Thanks for the response in advance,
Andy Delk
Best answer by jzupfer
Hello, Andy,
In case you haven't seen it, there is PTC documentation available for both WinDU and WinRU. The Windchill Diagnostic Utility Guide describes how to use WindDU and provides reference information for each available task. The list of tasks also specifies when it is necessary to run WinRU.
In addition, there is an administrative checklist available in the Windchill Help Center; it recommends running WinDU as a monthly or quarterly task.
Perhaps you're already familiar with this documentation and didn't find it sufficient; if that is the case, please let me know what we could do to make it more helpful.
Jane
Jane Zupfer
VP, Windchill Publications
T 763.957.8299
E -
jzupfer1-VisitorAnswer
Hello, Andy,
Jane
Jane Zupfer
T 763.957.8299
E -
Thanks . Ya basically that is the answer that I already know. I was just wondering if there were any other reasons. I appreciate the speedy response Jane!
You're most welcome, Andy. As you're using the documentation, please let me know if you think of things we could add or change.
Jane
