Aug 12, 2025 1:45 PM UTC
How does creo view files proces effectivity
Hello.
I'm new to the software so i'm having a hard time finding this answer.
Having some issues with generating creo view files. Actualy wondering how it is processed.
1- model generated in 2015, generates relatively small file(s) 50mb
2- same model now in 2025 generated with a lott of files/size 700mb
Does the generator first process all changes from 2015 till 2025, then work backwards towards effectivity date? any documentation how this is processed.  And are there methods of limmiting prpcessing time and files?
john.
Aug 14, 2025 6:41 AM UTC
Thanks for the feedback, I think I get the picture.
avillanueva
23-Emerald II
Aug 12, 2025 2:07 PM UTC
Publishing is based on the configuration chosen and the wvs settings at the time. For example, you can choose to publish latest vs as stored. This can obviously be different and result in different sizes. Even if you publish as-stored, if iterations have been purged, that as-stored base line cannot be honored. Next would be the WVS settings. Are you publishing as a position assembly or all models under a single PVZ of all components. Then there is the publishing adapter version and the level of detail settings in the recipe file. You would think that over time, file size would get smaller and more compact but that is not a guarantee.
In your example, if its a single model, its likely the recipe file and adapter version that are different. You might be publishing annotations, layers, and features.
Aug 13, 2025 6:34 AM UTC
Thanks for the reply.
> As stored, this would be a baseline/snapshot version at the given time 2015, a separate file/version
this would be different from both the 2015 and 2025 version, since its based on a fixed time/date.
>purged items, yes. What's purged can't be added.
Yes, high likelihood since its been 10 years. And with new versions most likely new settings/config.
> File size
I was expecting a larger file due to recorded changes, revisions etc 🙂
Any documentation on that i can read, processing with a effectivity date? Still looking myself.
maybe a better question would be:
Would a publish with the same settings etc but run with effectivity date result in a different file size/longer load time?
This due to the processing steps, first running to current date , then ''removing'' the effectivity date changes backwards.
avillanueva
23-Emerald II
Aug 13, 2025 11:50 AM UTC
In your case, did you see a difference with a single part model or was it an assembly?
