How to avoid conflicts at opening ?
Hello all,
I would like to find a way to avoid "automatic" modifications occuring at assemblies' opening... Each time an assembly is opened in our data basis, the conflicts' window appears requiring the user to choose "Continue" or "Check out" for many objects. I think there are two ways to avoid this :
- Set the "Continue" value as default :
>> What is the config.pro parameter which allows that ?
- Find why modifications are done at opening (postregeneration relations, dependencies, ...)
>> Did someone experience the same thing ? How to solve that... ?
