How to confiture PDM values to publish in Creo Title Block need some example
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.6 I would like to publish values on Workgroup manager of Creo parameter. please schedule a call to discuss on the same Here are the errors that I faced No error
Catalina
Community Manager
Hello ​@SC_14605927
Please know that your issue has been posted on the PTC Community, which is a peer-to-peer public support  community. In order to reach PTC Tech Support, please open a case here: Open a Support Case | PTC
Best regards,
Catalina | PTC Community Manager
Thanks for your email. Having issue to submit the case in PTC Support website. Working on it to fix the issue!
Dobi
​@SC_14605927
Firstly, Workgroup Manager is not the interface for Creo Parametric but is instead used for non-PTC CAD (like Solidworks, NX, Catia, etc.). Windchill is built into Creo Parametric.
When you say you want to “publish values on Windchill of Creo” are you talking about displaying model values in the workspace/commonspace views? Or the other way around - displaying Windchill system attributes within Creo parameters?
If you’re specifically asking about publishing - as in using Windchill Visualization Services with a CAD worker - that’s a separate set of questions.
I am referring to publish values from Windchill system attributes to Creo parameters. yes, windchill visualization services with a cad worker
Dobi
Ok.
First, there’s a parameter mapping that you need to account for in Creo that maps your parameters to Windchill attributes.
https://support.ptc.com/help/windchill/r13.1.1.0/en/index.html#page/Windchill_Help_Center/ProEWCInteg/ProEWCIntegCustProEParamWCAttrMap.html#
Even though the above is 13.1, the same is relevant to 12.1 and older versions.
If you want to have your Windchill attributes (like State, Revision, Number, etc.) displayed on something like a drawing, commonly these are added to the drawing template and they publish that way. Depending on your CreoView adapters there are further overlay options within publish rules (a post on this).
Alternatively, you can add note overlays on the drawing for the same… or you can get fancier with Windchill Extension overlays are even write your own with something like pdfbox (this post).
What attributes are you trying to publish and where (model, drawing)?
