Jul 8, 2015 6:19 PM UTC
How to copy the file content of the source object to the target existing object as a new iteration (or revision)?.
I am looking to perform a "Save As" operation on an assembly. Certain parts of my assembly have already been saved as the file name I want to use from previous "Save As" operations on similar assemblies.
Ex. PartA needs to become 123-PartA. 123-PartA already exists in WindChill.
I need WindChill to offer the override to create a new iteration of 123-PartA using my source file or allow me to substitute the existing 123-PartA into my assembly. The latter was available when my company used Pro/Intralink.
I have already performed the steps here to no avail.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS94283&art_lang=en&posno=2&q=saveas.replace.w.ws.content&source=search
I do not know what else I can do to get WindChill to allow display this override option.
Thanks you for any input,
Matt P.
Jul 9, 2015 1:39 PM UTC
A day after we updated the code on the server, it seems to have updated throughout the system. For some reason it didn't happen after our restart yesterday and didn't take effect until today.
Jul 8, 2015 6:35 PM UTC
You have PartA on your disk and you need it to become 123-PartA in Windchill?
Open Creo
In your Creo browser, download 123-PartA from Windchill
Rename PartA to 123-PartA on disk
Open 123-PartA from disk
Save the file and upload/check-in
This should override the 123-PartA from Windchill with the PartA you had on disk into Windchill as 123-PartA.
Now for the big question....WHY are you working offline???????
When using Windchill you should always do your work while connected.
Jul 8, 2015 6:42 PM UTC
I am working online. I am using the File>Save As operation from the WindChill browser in Creo.
I do have a similar topic where I attempted to do this offline to bypass the problem I am having in this thread. Unfortunately, doing what you suggest does not work for my more complicated assemblies.
Matt P.
TomU
This option does work.  We've been running this way since 9.1 M050 (now on 10.2 M020).  Did you restart Windchill after making the change?  Are you doing the rename in the workspace (not in Creo)?  After giving the objects new names you should get a conflict dialog with the little doctor's bag icon that let's you choose to checkout or revise and checkout.
Jul 8, 2015 6:45 PM UTC
No Doctor's Bag, only a failure notification. It does allow me to retry it, but it just fails repeatedly.
Yes, I am doing the save as / rename operation through WindChill.
I did restart WindChill as well. As a side-note we are running 9.1 M070, so this fix should have worked fine.
Matt P.
TomU
Jul 8, 2015 7:16 PM UTC
Do you have the Windchill Site Preference, "SaveAs -> Allow Replace" set to TRUE?
Jul 8, 2015 6:57 PM UTC
If your PartA and 123-PartA are both in Windchill, are they the same design?
In Creo, do a part substitution to replace the assembly component PartA with the 123-PartA that is in Windchill and then save your assembly.
Jul 8, 2015 7:19 PM UTC
They are the same design, the problem is the amount of parts that I would need to substitute. In some cases, I have hundreds of files that need to be replaced. WindChill should offer an option to replace these parts and perform the substitution for me, hence the link I shared in my original post.
mparmenteri12-AmethystAuthorAnswer
