how to create groups using LoadFromFile utility
  • November 25, 2010
  • 8 replies
  • 2944 views
hi,
I tried to create a groups by LoadFromFile Utility, but i got the errors like
these,
C:\ptc\Windchill_9\Windchill\loadFiles>windchill wt.load.LoadFromFile -d groups.xml
Error detected in createUserGroup <ast authors=">
Loader method wt.load.LoadUser.createUserGroup reported a failure
No objects were imported due to the error.
Unexpected problem in export/import process.
Nested exception is: wt.util.WTException: Loader method wt.load.LoadUser.createUserGroup reported a failure Error loading data from file.
data file = <groups.xml,c:\ptc\windchill_9\windchill\loadfiles\groups.xml>
map file = <null,null>
token separator = <null,null>
method = <null,create>
user = <null>
Command line = <{}>
and my groups.xml file :
<nmloader>
<csvusergroup handler="wt.load.LoadUser.createUserGroup">
<csvuser></csvuser>
<csvgroupname>Authors</csvgroupname>
<csvusername>ast</csvusername>
</csvusergroup>
<csvuser></csvuser>
<csvusername>ddb</csvusername>
</csvusergroup>
</nmloader>
What am I missing?
- Shreyas Atre
November 26, 2010
Shreyas
The xml you're using is supposed to add existing user to existing group. So you're probably getting the error because you have no 'ast' user and/or have no 'Authors' group in the container you're trying to load data (Site level in your case, since you're not using the -CONT_PATH)
To just create a group, use the following:
<nmloader>
<csvgroup handler="wt.load.LoadUser.createGroup">
<csvuser></csvuser>
<csvgroupname>TestGroup</csvgroupname>
<csvdescription>TestDataLoadGroup</csvdescription>
</csvgroup>
</nmloader>
November 26, 2010
thanks Dmitry,
Now I m able to create group, but how to add existing user to group I am using
<nmloader>
<csvuser></csvuser>
<csvusername>approver1</csvusername>
</csvgroup>
</nmloader>
it gives error
C:\ptc\Windchill_9\Windchill\loadFiles>windchill wt.load.LoadFromFile -d groups.xml -u wcadmin -p wcadmin -CONT_PATH \"/wt.inf.container.OrgContainer=Royal"
Error in XML input file Error loading data from file.
data file = <groups.xml,c:\ptc\windchill_9\windchill\loadfiles\cust\groups.xml>
user = <null>
Command line = <{CONT_PATH=/wt.inf.container.OrgContainer=Royal}>
Approver1 is existing user in Royal org,what I am missing?
- Shreyas
Try createGroupGroup example of usage in sample load files.
Everything you need to know is in the example xml load files, just open them up and you'll figure this out in no time.
Sent from my Verizon Wireless BlackBerry
Sheyas,
Try this for loading users into groups.
<csvuser></csvuser>
<csvgroupname>PDMLink Users</csvgroupname>
<csvusername>cd03882</csvusername>
<csvdirectoryservice></csvdirectoryservice>
</csvusergroup>
This is what I used to load users into groups.
HTH,
Alexius C. Chukwuka
JDPS Division SAP BASIS Team
John Deere Power Systems
November 27, 2010
Shreyas, use
<nmloader>
<csvuser></csvuser>
</csvusergroup>
</nmloader>
Also, since you're using -CONT_PATH \"/wt.inf.container.OrgContainer=Royal" when adding approver1 to the group TestGroup, make sure you have the group created in the Royal org, not on the Site level.
In Reply to Shreyas Atre:
thanks Dmitry,
<nmloader>
<csvuser></csvuser>
</csvgroup>
</nmloader>
it gives error
- Shreyas
November 30, 2010
Thanks Dmitry Tsarev,Alexius Chukwuka your suggestion works for me.
Hi All,
I'm trying to load and existing user to an existing group using the LoadFrom File utility and i'm getting an error
G:\PTC\Windchill_10.0\Windchill\loadFiles>windchill wt.load.LoadFromFile -d C:\Kiran\User_List\05-16-2013\testgroup.xml
Error detected in createUserGroup <emp00264 norma_applications_engineers=">
data file = <c:\kiran\user_list\05-16-2013\testgroup.xml,c:\kiran\user_list\05-16-2013\testgroup.xml>
user = <null>
Command line = <{}>
This is my xml file.
<nmloader>
<csvuser></csvuser>
<csvgroupname>NORMA_Applications_Engineers</csvgroupname>
<csvusername>emp00264</csvusername>
</csvusergroup>
</nmloader>
Any suggestions would be helpful.
Kiran Lakshminarayanan
20-Turquoise
May 17, 2013
On 05/17/13 11:59, Kiran Lakshminarayanan wrote:
> Hi All,
> getting an error
> user = <null>
> Command line = <{}>
> a failure
> <nmloader>
> <csvuser></csvuser>
> </csvusergroup>
> </nmloader>
Leave out the csvDirectoryService?
When I loaded existing users into existing groups I used the following format for csvUserGroup
<csvuser></csvuser>
<csvgroupname>Corporate</csvgroupname>
<csvusername>dougjone</csvusername>
</csvusergroup>
> Thanks,
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
