How to deploy custom logo (header.gif) in a Windchill Cluster setup?
  • November 19, 2012
  • 5 replies
  • 2682 views
Hi All,
I've been trying to change/include a different logo in the header top portion of Windchill PDMLink UI. The standard header would be a grey/green strip of image with white lettered transparent "Windchill" logo/image.
In a monolithic setup, I just had to change the below image:
Edit the image to include custom image/logo. There is no need even to restart Windchill or Tomcat. Just refreshing the page would reflect the changed image.
The same does not work with cluster setup. What steps should I follow to deploy the same in cluster setup?
Thanks in Advance,
Prabhakaran V.
7-Bedrock
November 19, 2012
Hello Prabhakaran,
In Cluster Enviornment, I.e On Master and Slaves We have to deploy all customizations.
As you done it in Monolitic Enviornment, Same steps to done on MAster and Slave Servers.
So whenever you access Windchill from Any of Slave you got same Header.gif on your browser.
Vivek
Prabhu10-MarbleAuthor
Hi Vivek,
Thanks for the reply.
Unfortunately, doing the same as in monolithic setup didn't work. I modified the header.gif image in both Master and Slave servers (same file - same location). Even did a restart of the application. Still no success.
Prabhakaran V.
Open the image directly from each server. Is it OK that way? Are you sure it's not a cache issue?
Hi Matthew,
Opening image directly from each server won't be the setup, but your other part of the reply helps. Was so ignorant to try once after clearning temporary internet files. I did so and there the modified logo goes..!!
Thanks All for your inputs,
Prabhakaran V.
