How to download & Save WTDocument primary content using Windchill API ?
  • July 25, 2013
  • 4197 views
I have a requirement like I need to download either primary or secondary content to WC Server Local HardDisk.
I am able to achive this using desktop.getdesktop().browse(new uri(Windchill_DocDownload_URL)) . If any better method is there please suggest.
Hi Manikandan,
Please try the following code in any utility class,
ContentHolder content = ContentHelper.service.getContents((ContentHolder)documentObject);
Vector<?> vcontent = ContentHelper.getApplicationData(content); // this will return all contents
if(vcontent.size() > 0){
for(int i=0; i<vcontent.size(); i++) {
wt.content.ApplicationData appData = (ApplicationData)vcontent.get(i);
String currfileName = appData.getFileName();
File saveAsFile= new java.io.File("D:/",currfileName); // input your location and file name
ContentServerHelper.service.writeContentStream((ApplicationData)appData, saveAsFile.getCanonicalPath());
you can also download the content for role too, have look on following method and modify to suit your requirement,
QueryResult getContentsByRole(ContentHolder holder, ContentRoleType role) throws WTException
public static final ContentRoleType PRIMARY
public static final ContentRoleType SECONDARY
Njoy,
MKR
Thanks a lot brother.
getContentsByRole(ContentHolder holder, ContentRoleType role) is perfect solution for my requirement.
and also I tried your above code ,In that if(vcontent.size() > 0) always not entering.
By
Mani
