How To find all "0" Level Parts from Windchill
  • August 16, 2013
  • 6 replies
  • 5340 views
Hi all,
I am Exporting Multilevel BOM from Windchill by API.. it Works..
now i want to export all BOM's present in Whindchill, so first i need to be find out the "0" Level Items from Windchill.
Plese let me know how i can do this ?
How i can find the TOP_LEVEl Parts from Windchill..
Vivek
Best answer by KD_01
In this line QueryResult rs = WTPartHelper.service.getUsesWTPartMasters(part); you are passing the part variable value as null which is leading to error.
Thanks and Regards,
Kaushik
Hi Vivek,
you can use queryspec to querying the database to get all the end items
GregoryPERASSO
If you use "End Item" to track top level assemblies , you can query the DB as Kaushik said.
if not , you have to query all WTPartsMasters, where the oid (ida2a2) does not exist is the WTPartUsageLink table (ida3b5). ie WTpart that are not used as child in a BOM.
You can do that query by API
vuchekar1-VisitorAuthor
Hi All,
I found a new way by using partUsageLink to find the TOP level parts from asm, but the code gives some error,
Please can you help me to sort out issu.
Code is:
WTPart part = null;
while(rs.hasMoreElements()){
System.out.println(""+rs.size());
System.out.println(part.getNumber()+"----Has----Child---"+rs.size());
WTPartMaster partMaster=(WTPartMaster)part.getMaster();
QueryResult qr_parents=WTPartHelper.service.getUsedByWTParts(partMaster);
while(qr_parents.hasMoreElements()){
WTPart parentPart = (WTPart)qr_parents.nextElement();
System.out.println(partMaster.getNumber()+"----Has----Parents---"+parentPart.getName());
partMaster =(WTPartMaster)parentPart.getMaster();
KD_0112-AmethystAnswer
Thanks and Regards,
Kaushik
