How to find all drawings required for an assembly ?
  • June 25, 2014
  • 3 replies
  • 3436 views
What is the best approach to finding all Drawings that are required for a certain high-level assembly to be built ? I can generate a +/- 5000 part structure and request for the CAD documents to be shown, but Windchill freezes on this one.
Since we're not sure of that drawing's number, folder or even context, we require a really generic solution. A Search based on number, attribute, ... is no option.
I've started looking into Query Builder, but I'm not really familiar with such tools to find a quick solution for this. I'm not even sure if QueryBuilder is the right tool for this...
Best answer by LoriSood
Are you wanting all the drawings for the dependent components of the assembly, too, or just ones related directly to the assembly?
If the latter, then you can view the Where Used on the Related Objects tab of the assembly to find out which drawings refer to it.
If the former, you could do as Mike suggests, or select to do any action that allows you access to the Collector (Add to Workspace, Check Out, etc.) and use the "Include Drawings" option to find which drawings are collected.
22-Sapphire I
June 25, 2014
Not sure but may be able to use either:
- Export, or
- Packages (Add to Package from top level object, create Package, Collect); can obtain the content of Packages externally
- Managed Baseline; download all published viewables of included drawings
Note: Query Builder can't understand structure in general.
LoriSood23-Emerald IIAnswer
23-Emerald II
July 1, 2014
The 'Add to Workspace' collectie is exactly the easiest solution we've found as well. Thanks.
