How to force user to change password
  • November 27, 2012
  • 1739 views
In my PDMLink system, we don't have for the moment an automatic mapping with corporate LDAP server.
So each user is created "manually", and password set with a default value.
The problem is that, the user don't change this initial password.
So, in PDMLink 9.1, do you know if there is a facility in the system to force the users to change the password?
Windchill does not place any restrictions on passwords. Please refer 'Setting Wiindchiill Diirrecttorry Server
Password Polices' in http://www.ptc.com/WCMS/files/124989/en/WCDirectoryServerAdminGuide.pdf
Though the option to manage the password change and restriction can be enabled in windchill by setting the following in wt.properties.
wt.org.services.userpasswordChangeEnabled
wt.org.userPasswordRestrictCharset
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS22777
Ofcourse, there is exception with special character usage after change and so the SPR is filed to address it. Not sure if patch is available for that.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS17326
