How to retrive multivalued attribute value in java program
  • April 30, 2014
  • 2 replies
  • 1792 views
HI
multivalued attribute value in using API?
Regards
Giridhar
11-Garnet
April 30, 2014
Giri,
Here is the two sets of main scripts. You need to build other logics based on your needs. I assume you are in 10 or above and looking API to get IBA values.
//load obj and get IBA Values of IBA
LWCNormalizedObject normalizedObject = new LWCNormalizedObject(wtPart, null, SessionHelper.getLocale(), null);
normalizedObject.load(ibaName);
Object ibaValue = normalizedObject.get(ibaName);
* This can be used to get only String type IBA value
public static String getIBAValues(Object ibaValue){
String ibaValues = ";
if(ibaValue instanceof Object[]) {
Object[] ibaValueArray = (Object[]) ibaValue;
for (Object aIbaValue : ibaValueArray) {
if ((ibaValues.length()) > 0) {
ibaValues = ibaValues + ",";
ibaValues = ibaValues + (String) aIbaValue;
else{
ibaValues = (String)ibaValue;
return ibaValues;
Shown code only to retrieve string type. You can adjust code to take care other data types.
Ayyappan
Thanks Ayyappan.
It worked perfectly fine.
On Wed, Apr 30, 2014 at 6:05 PM, Rajagopal, Ayyappan <
-> wrote:
> Giri,
> values.
> ** This can be used to get only String type IBA value*
> *public static String getIBAValues(Object ibaValue){*
> * String ibaValues = ";*
> * if(ibaValue instanceof Object[]) {*
> * Object[] ibaValueArray = (Object[]) ibaValue;*
> * for (Object aIbaValue : ibaValueArray) {*
> * if ((ibaValues.length()) > 0) {*
> * ibaValues = ibaValues + ",";*
> * ibaValues = ibaValues + (String)
> aIbaValue;*
> * else{*
> * ibaValues = (String)ibaValue;*
> * return ibaValues;*
> other data types.
> Thanks
> Ayyappan
> *From:* Giri G [
