How to search multiple WTDocument numbers through WC API
  • June 2, 2014
  • 5 replies
  • 3216 views
I am trying to find multiple document numbers through WC API.
If I use only one part number in below code, it works fine. If I use search string like "65832A00.*;1234.*" it won't return anything.
qs = new QuerySpec(wtDocCls);
SearchCondition sc = new SearchCondition(WTDocument.class, WTDocument.NUMBER, SearchCondition.LIKE, "65832A00.*;1234.*");
qs.appendWhere(sc);
qr = PersistenceHelper.manager.find(qs);
How can I search multiple documents using API?
Try following (with modification for WTDoc).
final QuerySpec querySpec = new QuerySpec(WTPart.class);
querySpec.appendWhere(new SearchCondition(WTPart.class, WTPart.NUMBER, SearchCondition.LIKE, desiredPartNumber.replace('*', '%')), null);
final QueryResult partQueryResult = PersistenceHelper.manager.find((StatementSpec)querySpec);
OK. I am now using "65832A00.%;1234.%". That also do not work. I think I need to use qs.appendOr();
Below code works. But I have query string which contains 10 or more docs. I am thinking of appending Or condition in a loop. It seems that we can not directly use query string in code.
SearchCondition sc = new SearchCondition(WTDocument.class, WTDocument.NUMBER, SearchCondition.LIKE, "1234%");
qs.appendWhere(sc);
qs.appendOr();
SearchCondition sc1 = new SearchCondition(WTDocument.class, WTDocument.NUMBER, SearchCondition.LIKE, "65832A00.%");
qs.appendWhere(sc1);
You can concat you query results. For example:
qs.appendWhere(sc);
qr1 = PersistenceHelper.manager.find(qs);
qr2 = PersistenceHelper.manager.find(qs1);
qr2.append(qr1.method);
* check the method. It must be like "toObjectVector", don't remember...
