I have a custom column in a table. I am not able to update the column by selecting all the values present in the table. This is a table in Associate Distribution Target.
  • May 4, 2015
  • 15 replies
  • 7841 views
Best answer by IsmailShaik
Could you elaborate your question? If possible, add screen shots to make it more clear.
sahmed1-VisitorAuthor
Hi Ismail,
In my resulting objects table of Change Notice I want to add one column. I have one custom IBA. The values of that IBA will populate the column.
Do you have any idea? What are the steps to add the column?
I think you need to override the method "buildComponentConfig" of the MVC builder "com.ptc.windchill.enterprise.change2.mvc.builders.tables.ResultingItemsTableBuilder".
Hi Ismail,
Thanks for the reply. I am trying this. If I face any issue I will get back to you.
One more query. In the customize view of a table, there is a option called "Available Column". How can I add ootb attribute in that Available Columns"
As I had asked you earlier, its good to have screen shots explaining what you are trying to achieve here. By looking at what you have described, I have few questions.
1) Where is your custom action located? on the resulting Items table?
2) If yes, is it a table level action or row level action?
3) Regarding the JSP page here, is it OOTB associate distribution target page? or some custom page?
Also, it is good to post this in the community instead of a personal question. So that if anyone in the community has an answer, you will get it faster. Also, people can refer it later if they face same/similar issues.
-Ismail
Hi Ismail,
As per you query..
1)My custom action located in resulting Objects table of Change Task.
2)It's a table level action. After the selecting the value from the dropdown in jsp it will update the distribution target column in the table. I want to associate the resultant objects with distribution target.
3) This is not the ootb jsp page, as I have one more dropdown in the table.
My question is how can I get details of the objects I have selected from the table and then map the value to Distribution target iba.?
For your help , Here I have attached the screenshot of my resulting objects table.
Since your issues are resolved, please mark this question as answered.
