ildataloader command failing with ClassNotFoundException
  • October 27, 2011
  • 1418 views
Hi All,
I'm trying to migrate from Pro/I 3.4 to Windchill 10 M020. Till now, everything was good except when I tried to start data mapping.
The ildataloader command won't run. Gives java.lang.ClassNotFoundException
I verified the MAIN_CLASS location and there's a class file under <ILMigration>\codebase\com\ptc\migration\bin "ILDataloader.class"
One thing which I notice is MAIN_CLASS points to com.ptc.migration.bin.ILDataloader, however the original location is <codebase>\com\....
Does this causing any problem? Any environment variable do we need to set?
Any help would be great.
Chris
Best answer by ChrisPeters
Resolved. The problem was with the site.xconf file. Properties were not propagated to the wt.properties file properly. After correcting them and restarting the methodserver resolved the problem.
ChrisPeters1-VisitorAuthorAnswer
