Insert new iteration of an object.
  • June 4, 2014
  • 6 replies
  • 2226 views
Is there a way to insert a new object in between its revisions via code ?
Best answer by apatil-2
Hi Lori,
Actually that preference is for CAD documents and I was in need for WTDocument and I found that by default it is allowing to do insert operation for Doc.And even I was able to achieve it via code.
Thank you very much for your suggestion.
I used "check out, check in" for this problem.
apatil-212-AmethystAuthor
Even I am doing the same and getting the work done ,but in MS it throws the error that object is non latest and can't be checked out.
23-Emerald II
June 7, 2014
Avinash, there is a preference that controls the ability to check out non-latest iterations:
Site > Utilities > Preference Management > Create and Edit > Allow checkout of non-latest iterations
Default is to not allow the check out.
Emeritus
July 22, 2014
Good day Avinash,
Were you able to solve your issue?
Best,
Toby
Yes. I solved this.
