Intralink 10.0 Error: "Unable to extract a server stream from the connection"
'Chillers,
Has anyone encountered the followingerror message in the Event Manager?
A quick search of this Forum and PTC's Knowledge Base did not uncover theexact message.
I have a soleuser who is having intermittent network connection issues during his ProE / Intralink 10.0 sessions. He seems to be able to Check-In most files one-at-a-time, but when attempting to Check-In an assembly with multiple parts he is consistently getting the error as the multi-object Check-In fails.
All signs, of course, point to a shakey network connection but his system is new and he doesn't have any other network-connectivity symptoms beyond this Intralink 10.0 issue. This just started today. No major system changes made today (that I know of).
I'm having IT troubleshoot/verify the integrity of the user's network drop but I wondered if any of you have encountered this error message and if so what did you find was the ultimate culprit?
WF4 m210 / Ilink 10.0 m030
Win 7 / 64-bit / Lenovo laptop
Other users on similar (identical) systems don't have this problem.
I have already wiped out and recreated his local cache: problem still occurring.
TIA.
